The restart command did not work and after not been able to post a response because of some error I was getting from the server here, decided to reinstall and it works now. Now I’m wondering how to make a created ftp account read the domain public html, it gives me an access error… Anyways, thanks for the help! :]
You may want to create a “Website access FTP user”, rather than a standard account. Making a website access FTP user uses the public_html folder as the homedir, and can read/write files within there.
I tried what you have mentioned and it did not work. After installing the last batch of updates, the Bind got errors to restart and same thing with the ProFTPD… I have disabled the bind since I don’t I know what else to do, is there a way to remove and reinstall the ProFTPD? I mean, I am sure there is a way I just don’t know how :]
Another question, since you have been so kind, does webmin has some sort of APC cache module? and if so, what will be the procedure?
