Facing WordPress Restore Issue
I have lost Apache Webserver and MySQL Database Server. They won’t start. Don’t know what could have happened. I tried different ideas but had no luck so I moved my websites to a new hard drive.
I managed to move my 17 other websites to a new hard drive, but what is the best way to move the WordPress folder? I originally installed WordPress using Virtualmin script.
Local server.
Ubuntu 20.04.4
Webmin 1.991
Virtualmin7.04
Hi Alex,
You need the contents of the root folder it’s installed in and a backup of the MySQL database. The user & database name can be reset\new & just updated on the config file.
Assuming you have both:
  1. Create the new DB and user.
  2. Restore the DB backup
  3. Restore the folder (changing the DB name & credentials in the config file)
and you should be more or less there.
If you don’t have both the folder contents and the database backup - I don’t think you’ll be successful.
HIH
