Hello, in my previous post I asked how do I install a SSL for my hostname. Now I have an another issue. How do create a mail alias in my hostname? For example my hostname is host.example.com, and I want to create a mail alias webmaster@example.com, not webmaster@host.example.com. How do I do that? Please let me know if my question is unclear to you.
Method 1.
- Login to Virtualmin
- Click on ‘Edit Mail Aliases’ on the left
- Click ‘Add an alias to this domain’
- in the ‘Create Mail Alias’ form
5a. In Description, type Web Master
5b. In Name, select Mailbox (selected by default), type webmaster. Do not type ‘@example.com’
5c. Select check box ‘Forward to other Address?’ and type username@example.com - Click Create.
Method 2.
- Login to Virtualmin.
- Click ‘Manually Edit Aliases’ on the top right under ‘Mail Aliases’ page/heading.
- In the box, go to last line, hit enter once, and type webmaster:Web Master:webmaster@example.com
Thanks but I already know that, I can’t select my host name in the list from sidebar. My hostname doesn’t show up there, only shows those I add virtual server after Virtualmin installation.
Each domain that your server is supposed to receive mail for needs to be created as a virtual server in Virtualmin, otherwise it will not configure Postfix accordingly.
