Hello!
I 'd like to know how to export all data from “protected web directories” to a new server.
.files containing the data seem to be restored in the backup but the Webmin info structure of protected dirs.
Thank you
By default, if you backup a Virtual Server, everything about it should be backed up – including all the files associated with it.
When scheduling the backup, I might recommend going into Features and settings to make sure everything is enabled.
If everything is enabled, can you go over what exactly isn’t working correctly when you perform a restore?
