Help!!
I cannot access https://mydomain.com:10000 nor https://publicip:10000 either https://mylocalip:10000 on my computer at home but only outside, what can i do to in order to access it on my computer at home.
I guess it has to do with firewall zones and whatnot. You could just use SSH forwarding tbh and access it that way from anywhere. I don’t even put the web interface public.
@bigcup - hi, I think while and if you hosting your server from home like me then on lan you should not have any issue to access it. If you host it somewhere outside of your house, you may need to check your firewall configuration - also if you use something like fail2ban check firewall page within webmin if your ip (mean public ip in/from home isp) is not blocked… sometimes it happens.
