NB: the DNS zone reset button process has some issue which I will look at later. I just mentioned it in case anyone things that might fix things, i did’t.
This is my zone file with Nameservers and their related A records. I have swapped my real IP.
$ttl 3600
mbmdev.com. IN SOA ns1.mbmdev.com. root.ns1.mbmdev.com. (
2024081808
3600
600
1209600
3600 )
mbmdev.com. IN A 31.125.123.123
www.mbmdev.com. IN A 31.125.123.123
ftp.mbmdev.com. IN A 31.125.123.123
ns1.mbmdev.com. IN A 31.125.123.123
ns2.mbmdev.com. IN A 31.125.123.123
localhost.mbmdev.com. IN A 127.0.0.1
ns1.mbmdev.com. IN NS ns1.mbmdev.com.
ns2.mbmdev.com. IN NS ns2.mbmdev.com.
what I have tried
Disabling the website did not fix it. the error still showed
I have DNS for this domain and it allowed me to to run a “check configuration”, but when I re-enabled it, the error returned.
in the file, normally placed just after the SOA, and not the similar lines you have placed at the bottom of the file
so the file would look like this
$ttl 3600
2024081808
3600
600
1209600
3600 )
@ IN NS ns1.mbmdev.com.
@ IN NS ns2.mbmdev.com.
This is an error when I run the recheck virtualmin configuration. I do this for 2 reasons
the button telling me to re-check is always there.
I need to run this to re-generate the system SSL certificate because I was getting an error with dovecot starting because it could not find the hostname ssl
the only thin is my NS records do not have th @ but use the mbmdev.com domain.
$ttl 3600
2024082903
3600
600
1209600
3600 )
There is the difference I don’t use virtualmin to create the records I use webmin, this stems back to the days when Virtualmin did not have the ability to create DNS records and I have stuck with it
