i’ve changed tmp directory to /var/tmp… and now in miniserv.error i get:
Temp file clearing is not done for the custom directory /var/tmp
How can i fix?
How can i fix?
I’m not aware of an automated way of doing this.
If you just change Webmin’s temp directory to /var/tmp, but leave everything else using /tmp – that should keep things pretty clean.
I’ve changed to /var/tmp, the tmp directory for Php and MySQL too. Maybe have I to take back those dir?
Using /tmp as your temp dir for everything but Webmin would probably make things simpler
in my vps if i do “df -h” i get:
Filesystem Size Used Avail Use% Mounted on
/dev/hdv1 5.0G 1.8G 3.3G 35% /
none 16M 348K 16M 3% /tmp
Is possible to automatic redirect /tmp on main /dev/hdv1? for example with a symbolic link?
