Joncas
1
I just installed the Webmin 3.82-2.gpl upgrade and then tried to enable the parallel pbzip2
That prompts me to re-check the configuration, and at the end of that come this error message:
HTTP/1.0 500 Perl execution failed Server: MiniServ/0.01 Date: Wed, 10 Nov 2010 14:38:04 GMT Content-type: text/html Connection: close
Error - Perl execution failed
Undefined subroutine &virtual_server::compare_versions called at virtual-server-lib-funcs.pl line 11716.
Many thanks in advance for any insight !
Eric
2
It looks like someone recently opened a bug report about that:
https://www.virtualmin.com/node/16227
Can you try the suggestion mentioned in there, and let us know if that helps? Thanks!
Joncas
3
Hello Eric,
I tried the fix you proposed, but there were no hung webmin processes, and the issue remained after restarting webmin …
I’ll try rebooting the whole server tomorrow morning and see if that changes anything.
