Hey thanks for the reply…
The first command returned this:
tcp 0 0 10.10.0.5:53 0.0.0.0:* LISTEN
tcp 0 0 162.243.164.137:53 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN
tcp6 0 0 :::53 :::* LISTEN
udp 0 0 10.10.0.5:53 0.0.0.0:*
udp 0 0 162.243.164.137:53 0.0.0.0:*
udp 0 0 127.0.0.1:53 0.0.0.0:*
udp6 0 0 :::53 :::*
the second this:
Chain INPUT (policy DROP)
target prot opt source destination
ufw-before-logging-input all – 0.0.0.0/0 0.0.0.0/0
ufw-before-input all – 0.0.0.0/0 0.0.0.0/0
ufw-after-input all – 0.0.0.0/0 0.0.0.0/0
ufw-after-logging-input all – 0.0.0.0/0 0.0.0.0/0
ufw-reject-input all – 0.0.0.0/0 0.0.0.0/0
ufw-track-input all – 0.0.0.0/0 0.0.0.0/0
Chain FORWARD (policy DROP)
ufw-before-logging-forward all – 0.0.0.0/0 0.0.0.0/0
ufw-before-forward all – 0.0.0.0/0 0.0.0.0/0
ufw-after-forward all – 0.0.0.0/0 0.0.0.0/0
ufw-after-logging-forward all – 0.0.0.0/0 0.0.0.0/0
ufw-reject-forward all – 0.0.0.0/0 0.0.0.0/0
ufw-track-forward all – 0.0.0.0/0 0.0.0.0/0
Chain OUTPUT (policy ACCEPT)
ufw-before-logging-output all – 0.0.0.0/0 0.0.0.0/0
ufw-before-output all – 0.0.0.0/0 0.0.0.0/0
ufw-after-output all – 0.0.0.0/0 0.0.0.0/0
ufw-after-logging-output all – 0.0.0.0/0 0.0.0.0/0
ufw-reject-output all – 0.0.0.0/0 0.0.0.0/0
ufw-track-output all – 0.0.0.0/0 0.0.0.0/0
Chain ufw-after-forward (1 references)
Chain ufw-after-input (1 references)
ufw-skip-to-policy-input udp – 0.0.0.0/0 0.0.0.0/0 udp dpt:137
ufw-skip-to-policy-input udp – 0.0.0.0/0 0.0.0.0/0 udp dpt:138
ufw-skip-to-policy-input tcp – 0.0.0.0/0 0.0.0.0/0 tcp dpt:139
ufw-skip-to-policy-input tcp – 0.0.0.0/0 0.0.0.0/0 tcp dpt:445
ufw-skip-to-policy-input udp – 0.0.0.0/0 0.0.0.0/0 udp dpt:67
ufw-skip-to-policy-input udp – 0.0.0.0/0 0.0.0.0/0 udp dpt:68
ufw-skip-to-policy-input all – 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type BROADCAST
Chain ufw-after-logging-forward (1 references)
LOG all – 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW BLOCK] "
Chain ufw-after-logging-input (1 references)
Chain ufw-after-logging-output (1 references)
Chain ufw-after-output (1 references)
Chain ufw-before-forward (1 references)
ACCEPT all – 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
ACCEPT icmp – 0.0.0.0/0 0.0.0.0/0 icmptype 3
ACCEPT icmp – 0.0.0.0/0 0.0.0.0/0 icmptype 4
ACCEPT icmp – 0.0.0.0/0 0.0.0.0/0 icmptype 11
ACCEPT icmp – 0.0.0.0/0 0.0.0.0/0 icmptype 12
ACCEPT icmp – 0.0.0.0/0 0.0.0.0/0 icmptype 8
ufw-user-forward all – 0.0.0.0/0 0.0.0.0/0
Chain ufw-before-input (1 references)
ufw-logging-deny all – 0.0.0.0/0 0.0.0.0/0 ctstate INVALID
DROP all – 0.0.0.0/0 0.0.0.0/0 ctstate INVALID
ACCEPT udp – 0.0.0.0/0 0.0.0.0/0 udp spt:67 dpt:68
ufw-not-local all – 0.0.0.0/0 0.0.0.0/0
ACCEPT udp – 0.0.0.0/0 224.0.0.251 udp dpt:5353
ACCEPT udp – 0.0.0.0/0 239.255.255.250 udp dpt:1900
ufw-user-input all – 0.0.0.0/0 0.0.0.0/0
Chain ufw-before-logging-forward (1 references)
Chain ufw-before-logging-input (1 references)
Chain ufw-before-logging-output (1 references)
Chain ufw-before-output (1 references)
ufw-user-output all – 0.0.0.0/0 0.0.0.0/0
Chain ufw-logging-allow (0 references)
LOG all – 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW ALLOW] "
Chain ufw-logging-deny (2 references)
RETURN all – 0.0.0.0/0 0.0.0.0/0 ctstate INVALID limit: avg 3/min burst 10
Chain ufw-not-local (1 references)
RETURN all – 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type LOCAL
RETURN all – 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type MULTICAST
RETURN all – 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type BROADCAST
ufw-logging-deny all – 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 10
Chain ufw-reject-forward (1 references)
Chain ufw-reject-input (1 references)
Chain ufw-reject-output (1 references)
Chain ufw-skip-to-policy-forward (0 references)
Chain ufw-skip-to-policy-input (7 references)
Chain ufw-skip-to-policy-output (0 references)
Chain ufw-track-forward (1 references)
Chain ufw-track-input (1 references)
Chain ufw-track-output (1 references)
ACCEPT tcp – 0.0.0.0/0 0.0.0.0/0 ctstate NEW
ACCEPT udp – 0.0.0.0/0 0.0.0.0/0 ctstate NEW
Chain ufw-user-forward (1 references)
Chain ufw-user-input (1 references)
ACCEPT tcp – 0.0.0.0/0 0.0.0.0/0 tcp dpt:22
ACCEPT udp – 0.0.0.0/0 0.0.0.0/0 udp dpt:22
ACCEPT tcp – 0.0.0.0/0 0.0.0.0/0 tcp dpt:80
ACCEPT tcp – 0.0.0.0/0 0.0.0.0/0 tcp dpt:443
ACCEPT tcp – 0.0.0.0/0 0.0.0.0/0 tcp dpt:25
ACCEPT tcp – 0.0.0.0/0 0.0.0.0/0 multiport dports 80,443 /* ‘dapp_Apache%20Full’ */
ACCEPT tcp – 0.0.0.0/0 0.0.0.0/0 tcp dpt:10000
ACCEPT udp – 0.0.0.0/0 0.0.0.0/0 udp dpt:10000
Chain ufw-user-limit (0 references)
LOG all – 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 5 LOG flags 0 level 4 prefix "[UFW LIMIT BLOCK] "
REJECT all – 0.0.0.0/0 0.0.0.0/0 reject-with icmp-port-unreachable
Chain ufw-user-limit-accept (0 references)
Chain ufw-user-logging-forward (0 references)
Chain ufw-user-logging-input (0 references)
Chain ufw-user-logging-output (0 references)
Chain ufw-user-output (1 references)
Thanks again.
