| SYSTEM INFORMATION | |
| OS type and version | Almalinux 9.8 |
| Webmin version | 2.670 |
| Virtualmin version | 8.3.0 Professional |
The auto-renewal SSL produces an error for me:
2026-10-01 13:23:33,219:INFO:certbot._internal.auth_handler:Challenge failed for domain vom-bruch.com
Certbot failed to authenticate some domains (authenticator: manual). The Certificate Authority reported these problems:
Hint: The Certificate Authority failed to verify the DNS TXT records created by the --manual-auth-hook. Ensure that this hook is functioning correctly and that it waits a sufficient duration of time for DNS propagation. Refer to "certbot --help manual" and the Certbot User Guide.
raise errors.AuthorizationError('Some challenges have failed.')
certbot.errors.AuthorizationError: Some challenges have failed.
2026-10-01 13:23:40,804:ERROR:certbot._internal.log:Some challenges have failed.
it complained about an _acme challenge record, but I use wildcard dns entry, i dont see the wrong TXT tit complains about.
When I manually request a cert it works fine.
