Error - Perl execution failed - Refresh System Information
I just upgraded the following packages on two of my Virtualmin VPS’s:
wbm-virtualmin-awstats Webmin module for ‘AWstats Reporting’ 5.1-1
wbm-virtualmin-dav Webmin module for ‘Virtualmin DAV’ 3.7-1
wbm-virtualmin-init Webmin module for ‘Virtualmin Bootup Actions’ 2.5-1
wbm-virtualmin-mailman Webmin module for ‘Virtualmin Mailman Mailing Lists’ 6.3-1
wbm-virtualmin-svn Webmin module for ‘Virtualmin Subversion Repositories’ 5.1-1
wbt-virtual-server-theme Webmin theme ‘Virtualmin Framed Theme’ 9.0-1
Now when I click Refresh System Information on the System Information page, I get the following error on both systems:
Undefined subroutine &main::right_page_cgi called at /usr/libexec/webmin/virtual-server-theme/recollect.cgi line 10.
You may want to try restarting Webmin, which can be done with this command:
/etc/init.d/webmin restart
If that doesn’t help, you may be seeing the issue described here:
http://virtualmin.com/node/35824
That did not resolve the issue. I will watch the bug thread, but I’m in the same boat with the issue.
