how to solve Fatal Error: ezSQL_mysql requires MySQL Lib to be compiled and or linked in to the PHP engine error on virtualmin ?
Trying to install PHP Vibe script on the virtual server all setup perfectly but getting this error Fatal Error: ezSQL_mysql requires MySQL Lib to be compiled and or linked in to the PHP engine
Virtualmin is open stuff, cpanel is not even close to anything virtualmin is.you are not running cpanel perhaps you was not asking right questions towards developers
I asked them that we are using Virtualmin and Webmin trying to install your script on our virtual server but getting this error. they told us that this error will be fixed from your dashboard/server.
They also told us, If you were using Cpanel you would have fixed the problem with the help of this article. but here you are using a Webmin/Virtualmin in a dedicated server so we are only able to fix problems if in our script. but here is the problem with your server contact your server(hosting) provider it will help you.
I would suggest checking if it is actually getting loaded for given virtual server by creating index-phpinfo.php small file with the following content:
<?php
phpinfo();
… and opening it in your browser … if everything looks good, it’s not something we could assist you with. As this question should be asked on PHP Vibe community.
Thanks, Richard for pointing out but the short tag is referred as <? while I mentioned <?php , only omitting closing tag, which is not mandatory in this case.
