This happened some time after a recent virtualmin upgrade. When I click on View Report, I get Error - Missing Headers in the right side frame.
This happens on any domain. Webalizer works ok. Virtualmin 3.64.gpl GPL
Any ideas?
Any ideas?
When I ran re-check config, I got this:
[code:1]The AWstats command /usr/share/awstats/wwwroot/cgi-bin/awstats.pl was not found on your system.[/code:1]
If you run this:
find /usr -name awstats.pl
What directory does it show up in?
Then, if you log into Virtualmin, and click System Settings -> Features and Plugins -> Awstats -> Configure – does the path listed there match where awstats.pl resides?
I did a search on that after I got the error. I pointed it to /etc/webmin/virtualmin-awstats/awstats.pl . But there was more than one awstats.pl listed (3). It was pointed to /usr/share/awstats/wwwroot/awstats.pl.
Any ideas where it should be pointed?
Well, it’s likely to be one under /usr/ (but not under webmin) or possibly /var.
The one you see under /etc is part of the Virtualmin module, rather than the actual awstats package.
Mine points to /usr/lib/cgi-bin/awstats.pl, but I’m on Ubuntu.
What are the other awstats.pl versions you see?
Here’s the others:
[code:1]/etc/webmin/virtualmin-awstats/awstats.pl
/usr/libexec/webmin/virtualmin-awstats/awstats.pl
/var/www/awstats/awstats.pl
[/code:1]
Okay, try using /vat/www/awstats/awstats.pl – if that doesn’t work, pop a bug report into the Bugs and Issues tracker, as we may need Jamie’s help to get us on the right track here
Looks like I got it resolved.
AWstats configuration directory: /etc/awstats
Full path to AWstats program: /var/www/awstats/awstats.pl
Full path to AWstats icons directory: /var/www/awstats/icon
Lang, Lib, Plugins: Same as awstats.pl
