Error: First Installation
Hello everyone!!!
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
FATAL - Fatal Error Occurred: Something went wrong during installation: 0
Thank you very much!!!
You may want to take a peek at the /root/virtualmin-install.log mentioned above to see if any errors show up in there.
Also, what distribution/version are you installing onto? How much RAM do you have? And are you using a dedicated server or a VPS?
Thanks,
