Hi, during the installation of VirtualMin on Debian Linux 7.0, Linux 2.6.32-5-amd64 on x86_64 I got this error:
INFO - 2013-05-16 16:25:14 - /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install postfix postfix-pcre webmin usermin ruby libapache2-mod-ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip libfcgi-dev bind9 spamassassin spamc procmail libnet-ssleay-perl libpg-perl libdbd-pg-perl libdbd-mysql-perl quota iptables openssl python mailman subversion ruby irb rdoc ri mysql-server mysql-client mysql-common postgresql postgresql-client awstats webalizer dovecot-common dovecot-imapd dovecot-pop3d proftpd libcrypt-ssleay-perl awstats clamav-base clamav-daemon clamav clamav-freshclam clamav-docs clamav-testfiles libapache2-mod-fcgid apache2-suexec-custom scponly apache2 apache2-doc libapache2-svn libsasl2-2 libsasl2-modules sasl2-bin php-pear php5 php5-cgi libgd2-xpm libapache2-mod-php5 php5-mysql: Succeeded.
INFO - 2013-05-16 16:25:14 - Succeeded.
INFO - 2013-05-16 16:25:14 - Installing Virtualmin and all related packages now using the command:
INFO - 2013-05-16 16:25:14 - /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install virtualmin-base
Reading package lists…
Building dependency tree…
Reading state information…
WARN - apt-get seems to have failed. Are you sure your OS and version is supported?
WARN - http://www.virtualmin.com/os-support
Can somebody help me?
