ERROR: Connection dropped by IMAP server.
up
It looks like you have a variety of third party repositories installed.
Those can cause a variety of problems.
So first off, my suggestion would be to disable all third party repositories.
Second, I don’t see the Virtualmin repository mentioned in the above. So once all the third party repositories are disabled, I’d suggest making sure that the Virtualmin repository is enabled.
can u tell how could i disable all third party repositories in my vps and how can i endable the Virtualmin repository?
thanks
i have alle the files in the yum.repos.d disabled
CentOS-Base.repo CentOS-fasttrack.repo CentOS-Vault.repo epel-testing.repo webmin.repo webtatic.repo
CentOS-Debuginfo.repo CentOS-Media.repo epel.repo remi.repo webtatic-archive.repo webtatic-testing.repo
enabled=0 is this what did u mean ?
but nothing changed
Well, we’re getting a bit off the original topic here, which might make things a bit tough to keep track of.
So why don’t we do this –
Can you start a new Forum thread, and in that thread, let us know the issue that you’re currently seeing – the errors you’re seeing when installing dkim-milter, and the files that you have in /etc/yum.repos.d.
Also, let us know how you initially performed you’re Virtualmin installation – whether it was done using the install.sh, or whether it was done using some other method.
Thanks!
