Research ‘no route to host’ rather than just repeating the error you have
You sure this is open on your firewall?
!X (communication administratively prohibited),
traceroute to 184.174.32.123 (184.174.32.123), 30 hops max, 60 byte packets
1 _gateway (192.168.0.1) 0.347 ms 0.401 ms 0.487 ms
2 syn-142-254-157-021.inf.spectrum.com (142.254.157.21) 21.636 ms 21.748 ms 21.605 ms
3 * * *
4 lag-25.pltsohae01r.netops.charter.com (24.33.103.230) 13.764 ms 13.750 ms 13.734 ms
5 lag-30.rcr01clmkohpe.netops.charter.com (65.29.1.40) 17.519 ms 19.070 ms 18.964 ms
6 * * *
7 ae13.edge2.chi10.sp.lumen.tech (4.68.37.137) 29.699 ms 29.618 ms 53.617 ms
8 * ae1.3107.edge6.dus1.neo.colt.net (171.75.9.193) 123.473 ms 123.624 ms
9 giga-hostin.ear2.dusseldorf1.level3.net (62.67.20.82) 123.695 ms giga-hostin.edge6.dusseldorf1.level3.net (62.67.22.194) 123.502 ms giga-hostin.ear2.dusseldorf1.level3.net (62.67.20.82) 123.657 ms
10 jv80.se (184.174.32.123) 126.377 ms !X 119.988 ms !X 121.376 ms !X
Yes Its the same answer if I disable the firewall, its CSF
I don’t know what to tell you then. The traceroute stops at server 184.174.32.123.
This tells me ssh is listening on that port. If the firewall isn’t stopping it I don’t know what else would be. At this point, if it were me, I’d turn on packet logging and see what is happening to those packets.
That is the server. I have made a tickett to the provider but they are not the fastest. Anyway for now I will go back to 22. With a keypair and passphrase its quite secure anyway
Thanks for your time
Better you hint me about more I can do. Seems to me that it something with that server.
