Enabling SSL
hi,
I’ve installed Webmin and everything is working fine besides the part of enabling SSL.
I followed the HOWTO on Webmins website(http://www.webmin.com/ssl.html) on howto install OpenSSL and Net::SSLeay Perl module. Everything compiled and installed with no errors.
On Step#7 it says to enable/turn on SSL look for ‘SSL Encryption’ under Webmin, click on it an choose enable/disable BUT, i cant see any option saying ‘SSL Encryption’ :confused:
Am i going blind?
Can someone help please?
Thanks alot!
Ok, yea i was going blind. No worrys, found it!
