ok I have some domains setup. All is working.
But The email gets rejected if it sent to abc@mail.abc.com
it goes through if it is abc@abc.com
How do I make it so both are valid?
Can you paste in the exact error you’re getting?
And, is mail.abc.com setup as a Virtual Server on your system?
Also, what is your server’s hostname… is that different than mail.abc.com?
Lastly – if you go into System Settings -> Re-Check Config, do you see any problems?
