Email Random Problem (virtualmin gpl)
Hi I have installed a VPS with virtualmin gpl for administer my domains, i have 5 domains but only 2 manage mail services… everythin is ok but for monitoring I recently installed a script to get the resume of mail activity of day, my question is about random errors reported…
this this the output…
the first part of the mail for idea of the daily traffic
Grand Totals------------
messages
292 received
1099 delivered
313 forwarded
3 deferred (3 deferrals)
43 bounced
7 rejected (0%)
0 reject warnings
0 held
0 discarded (0%)
and the detail of boucend and fails system
message deferral detail-----------------------
local (total: 1)
1 local: fatal: execl /bin/sh: Too many open files in system
qmgr (total: 1)
1 unknown mail transport error
smtp (total: 1)
1 //postgrey.schweikert.ch/help/quirsa.com.html (in reply to RCP…
message bounce detail (by relay)
local (total: 42)
30 “/usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME”
3 mail forwarding loop for dcoxaj.sysvirtuales@admin.sysvirtuales…
2 libtermcap.so.2: cannot open shared object file: Error 23
2 mail forwarding loop for info.sysvirtuales@admin.sysvirtuales.com
1 libc.so.6: cannot open shared object file: Error 23
1 procmail: Unknown user “ricardo.int-rosenberg”
1 procmail: Unknown user “ventas.int-rosenberg”
1 Program failure (127) of "/etc/webmin/virtual-server/lookup-dom…
1 Program failure (-11) of "/etc/webmin/virtual-server/lookup-dom…none (total: 1)
1 User unknown in virtual alias table
I am beggining in postfix deployment, if you give me some help with these error I will appreciate…
tks…
Well, it’s not unusual to see some email errors… a lot of what you’re seeing there may simply be due to spammers guessing at incorrect usernames.
A few of those you may want to check out… what you’d want to do is look in the mail logs, and determine the context of when they’re occurring.
For example, “Too many open files in system qmgr” and “ibtermcap.so.2: cannot open shared object file” are a little unusual. My suggestion there would be to open /var/log/mail.log or /var/log/maillog, locate where those errors are, and determine what exactly was happening at that time that could have contributed to those errors.
Hi this one of the error showeds in maillog…
May 20 17:07:03 admin dovecot: execv(/usr/libexec/dovecot/pop3-login) failed: Too many open files in system
May 20 17:08:04 admin dovecot: execv(/usr/libexec/dovecot/pop3-login) failed: Too many open files in system
I think that the problem is some configuration on smtp server or somethin… the server are a VPS wiht 2 GB of ram and the number or email for each day are aprox 900 to 1000 mails… other problem is that I have aprox 30 forward rules for user in server (incoming rules and outgoing rules) some days I habe more tha 100 errors that this…
May 19 15:55:04 admin postfix/local[11544]: D606010068020: to=ricardo.int-rosenberg@admin.sysvirtuales.com, orig_to=analucia@int-rosenberg.net, relay=local, delay=0.98, delays=0.94/0/0/0.05, dsn=5.3.0, status=bounced (Command died with status 127: “/usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME”)
May 19 15:55:04 admin postfix/local[4022]: D7FFE10068022: to=ventas.int-rosenberg@admin.sysvirtuales.com, orig_to=aracely@int-rosenberg.net, relay=local, delay=0.98, delays=0.93/0/0/0.05, dsn=5.3.0, status=bounced (Command died with status 245: “/usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME”)
this problem are each day with randoms account sometimes do and sometimes not…
I need some help to solve this…
any help with tuning my server are apreciated…
You may be seeing a lot of traffic in Dovecot, enough to make it hit the open file limit for your server.
You can always try bumping up your open file limit in /etc/security/limits.conf.
As far as your email deliver issue goes – what do you see if you type this command:
ls -l /usr/bin/procmail-wrapper
tks …
in limits.conf I have setup this…
  • soft nofile 4096
  • hard nofile 4096
and for the command that you gave me the output is
-rwsr-sr-x 1 root root 4994 May 9 2007 /usr/bin/procmail-wrapper
Hmm, I have a suspicion that either those settings aren’t being seen, or you’re getting a crazy amount of traffic :slight_smile:
One thing you might try is to put the following in your limits file, then restart Dovecot:
dovecot hard nproc 8192 @dovecot hard nproc 8192
I will try this improvement, and I will see the perfomance tomorrow … how I can see the real traffic to my server?? there are some tool to monitor this?
Well, it wouldn’t likely be a high amount of bandwidth. However, you can see how many Dovecot processes are running at any given time with this command:
ps auxw | grep dovecot | wc -l
Hi the problem was continue…
there is my posfconf -n: please check if I have something worng
postconf -n
bounce_queue_lifetime = 120m
command_directory = /usr/sbin
config_directory = /etc/postfix
daemon_directory = /usr/libexec/postfix
debug_peer_level = 2
default_destination_concurrency_limit = 25
disable_vrfy_command = yes
home_mailbox = Maildir/
html_directory = no
inet_interfaces = all
local_destination_concurrency_limit = 4
mail_owner = postfix
mailq_path = /usr/bin/mailq.postfix
manpage_directory = /usr/share/man
maximal_backoff_time = 2000s
maximal_queue_lifetime = 120m
message_size_limit = 31457280
minimal_backoff_time = 500s
mydestination = $myhostname, localhost.$mydomain, localhost, admin.sysvirtuales.com
newaliases_path = /usr/bin/newaliases.postfix
queue_directory = /var/spool/postfix
queue_run_delay = 500s
readme_directory = /usr/share/doc/postfix-2.3.3/README_FILES
sample_directory = /usr/share/doc/postfix-2.3.3/samples
sendmail_path = /usr/sbin/sendmail.postfix
setgid_group = postdrop
smtpd_banner = $myhostname ESMTP $mail_name ($mail_version)
smtpd_error_sleep_time = 2s
smtpd_hard_error_limit = 30
smtpd_helo_required = yes
smtpd_sasl_auth_enable = yes
smtpd_soft_error_limit = 15
unknown_local_recipient_reject_code = 550
and I have a new problem in logs
May 27 12:37:48 admin postfix/smtpd[26356]: warning: 67A0CCA50B8C: queue file size limit exceeded
May 27 13:02:24 admin postfix/smtpd[26356]: warning: CA23FCA50B8C: queue file size limit exceeded
May 27 13:27:39 admin postfix/smtpd[26356]: warning: CF33ACA50B8C: queue file size limit exceeded
May 27 13:54:04 admin postfix/smtpd[26356]: warning: 0FC32CA50B8C: queue file size limit exceeded
and other thing a minutes ago the server was stop for too many open files…
I am really preocupated… the problem is no always but generate me problems with my clients…
tks for any possible help
Well, I’m not entirely certain what might cause those errors – but after a little Googling, one idea would be to try commenting out the “message_size_limit” line in your /etc/postfix/main.cf, then restart Postfix.
I’m curious if those emails go through after that, or whether you continue to receive the queue file size limit errors.
Hi the queue problem was fixed, but now I have several logs with this…
99 “/usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME”
I see that the problem is that too many open files are on system…
I was modified in limits.conf the soft and hard options to 32780…
if somebody can help me with this…
tks
Hmm, that doesn’t look like an error message… it’s normal to see “/usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME” – that’s the command that delivers all of your email.
Are you seeing any associated error messages with that when the email is being delivered?
the error was in a mail report that I receive every day…
there are bounce mails…
message bounce detail (by relay)--------------------------------
local (total: 146)
13 libdl.so.2: cannot open shared object file: Error 23
12 libtermcap.so.2: cannot open shared object file: Error 23
10 libc.so.6: cannot open shared object file: Error 23
5 sh: /usr/bin/procmail-wrapper: Too many open files in system
4 Program failure (-11) of "/etc/webmin/virtual-server/lookup-dom…
1 libnsl.so.
1: cannot open shared object file: Error 23
1 unknown user: "ventas.int-rosenberg"none (total: 1)
1 mail for gmail.sysvirtuales.com loops back to myself
You may want to make sure that there’s no limits setup in /etc/security/limits.conf that may be affecting mail delivery.
If you see any open file limits set in there, you may want to temporarily disable those, restart Postfix, and see if that helps.
Hi Eric I am really help with this server… could you give some special support to see the server? my clients are loosing mails for this…
I am really need that somebody check all configuration in server to setup the correct settings are enabled.
Hi everybody my problem still happen… I was modify the limits.conf… but the error Too many open files still happen… are you have a similar problem…
I have a VPS with 2GB of ram…
Well, I’m unfortunately not sure what the issue there is… I see that you posted a note in the Jobs forum for Scott to take a look, was he able to poke around on your server? Did he offer any thoughts/advice?
yes he told me about policyd implemetation… but the problem I think that not only the smtp request per hour in my system… I think that the problem are the dovecot conf… or http conf but I don’t be sure…
I have a question about that I run this command
lsof -n|grep -oE ‘[1]+’|sort|uniq -c|sort -n
and the result was
lsof -n|grep -oE ‘[2]+’|sort|uniq -c|sort -n
8 uniq
9 grep
9 init
14 syslogd
16 monit
16 sort
17 udevd
21 sh
22 collectin
22 dbus
24 lookup
25 lsof
25 munin
28 su
34 proftpd
35 pickup
35 qmgr
36 anvil
36 proxymap
38 postgrey
43 named
45 crond
49 bash
50 smtpd
78 pop
82 dovecot
99 yum
125 master
141 php
145 mysqld
160 saslauthd
166 imap
191 sshd
244 miniserv
2640 httpd
when I run > lsof | awk ‘{print $NF}’ | sort | wc -l
the number of files are betwen 4500 and 5800 when the number is high the problem is begin… I see in maximun open files in system… cat /proc/sys/fs/file-max the number 262144
why the number of files open not to be more than 6000 on my system if the settings are 262144 …
  1. a-z ↩︎
  2. a-z ↩︎
