Email Problems...
Hi there…
VIRTUALmin SEEMS POWERFUL… but…
i ve setuped from server templates mail domain… like user@domain
So now my users have user@domain for login at usermin and for using pop/smtp email…
But i have problem…
Users can’t send email (from user1@domain to user2@domain) and receive email into the domain… :-(I
at Thunderbird gives that error (ofcourse from mailserver):
Undelivered Mail Returned to Sender
This is the mail system at host UNKNOWN.
The mail system
cyberd.magma@localdomain (expanded from cyberd@magma.gr): unknown user:
“cyberd.magma”
The real email is actually cyberd@magma.gr not cyberd.magma@localdomain… but not cyberd.magma too…
…I must say have problem to get it with roundcube too… (so i am using for now - usermin)
What i must do ?
Thanks in advance
You may have multiple issues…
But, the most obvious issue is that you’ve got cyberd.magma in your virtual map file (/etc/postfix/virtual), but you’ve got a user with a different name. I don’t know how that would happen…maybe you changed the email format after creating the user? Changing the format does not change existing usernames.
You’ll either need to delete and recreate the user (easiest) or manually change it (for user@domain.tld format, this is particularly tricky as you need a second name of user-domain to make all software happy…not everything will work with user@domain.tld usernames).
@Joe for magma.gr domain
OK let’s forogot roundcube…
  1. How i will manually change the username ?
When i am getting email from different domain/servers all works perfect… when i am sending from user1@magma.gr to user2@magma.gr - return back…how i will fix it ?
  1. When creating new users - have the same problem… need to change anything at webmin>servers>postfix mail server… have many things (didn;t change anyhting yet) - or may be i need to change something at the domain because when email returns back… give that can find username at host (host: localdomain ?)…
may be a setting… will make the difference…
  • When sending from different virtual server (domaina.tld) email to the same ip different virtual server (domainb.tld) i have problem too… returns back only from outside works perfect.
  • the mail aliases are like these:
    cyberd Address cyberd.magma
    forwarding to cyberd.magma
is there the problem ?
Found this trick…
Get into Mail aliases of Virtual Server…
delete the
cyberd cyberd.magma
Create New
  • Check deliver locally writing username@domain.tld (mine!)
    Create…
WORKS now…
what was this ?
works from anywhere and from mail to mail into domain…too
am i right ?
AFter that…roundcube worked !!! too
