email problem
Hello every one
I was keep getting about email
i saw posting from joe but some thing i am not very clear how to fix
i am getting error when i try to add admin user
for admin@domain.com
Undefined subroutine & postfix::rebuild_map_cmd called at /usr/libexec/webmin/postfix/aliases
i love the fact virtualmin professional never gave me any problem but this is some thing i need to fix asap
I am also getting error on the forward email account the following error
his is the mail system at host ns2.domain.com.
I’m sorry to have to inform you that your message could not
be delivered to one or more recipients. It’s attached below.
For further assistance, please send mail to <postmaster>
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
               The mail system
<webmin@ns2.domain.com>: unknown user: "webmin"
now my email can not send and received from my server
here configration check for postfix
Configuration Check
Postfix Version: 2.3.3
Hostname ns2.domain.com.com
System Linux ns2.pcpluscomputing.com 2.6.18-92.1.18.el5 #1 SMP Wed Nov 12 09:30:27 EST 2008 i686 i686 i386 GNU/Linux
main.cf
non-default parameters
alias_maps hash:/etc/aliases
broken_sasl_auth_clients yes
home_mailbox Maildir/
mailbox_command /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME
mailq_path /usr/bin/mailq.postfix
manpage_directory /usr/share/man
mydestination $myhostname, localhost.$mydomain, localhost, ns2.pcpluscomputing.com
newaliases_path /usr/bin/newaliases.postfix
readme_directory /usr/share/doc/postfix-2.3.3/README_FILES
sample_directory /usr/share/doc/postfix-2.3.3/samples
sender_bcc_maps hash:/etc/postfix/bcc
sendmail_path /usr/sbin/sendmail.postfix
smtpd_recipient_restrictions permit_mynetworks permit_sasl_authenticated reject_unauth_destination
smtpd_sasl_auth_enable yes
virtual_alias_maps hash:/etc/postfix/virtual
main.cf
parameters defined as per defaults
alias_database hash:/etc/aliases
command_directory /usr/sbin
config_directory /etc/postfix
daemon_directory /usr/libexec/postfix
debug_peer_level 2
html_directory no
inet_interfaces all
mail_owner postfix
queue_directory /var/spool/postfix
setgid_group postdrop
smtpd_sasl_security_options noanonymous
unknown_local_recipient_reject_code 550
master.cf
service type private unpriv chroot wakeup maxproc command + args
inet
pickup
fifo
n
n
60
1
pickup
cleanup
unix
n
n
0
cleanup
qmgr
fifo
n
n
300
1
qmgr
tlsmgr
unix
n
1000?
1
tlsmgr
rewrite
unix
n
  • trivial-rewrite
    bounce
    unix
n
0
bounce
defer
unix
n
0
bounce
trace
unix
n
0
bounce
verify
unix
n
1
verify
flush
unix
n
n
1000?
0
flush
proxymap
unix
n
  • proxymap
    smtp
    unix
n
  • smtp
    relay
    unix
n
  • smtp
    -o
    showq
    unix
n
n
  • showq
    error
    unix
n
  • error
    discard
    unix
n
  • discard
    local
    unix
n
n
  • local
    virtual
    unix
n
n
  • virtual
    lmtp
    unix
n
  • lmtp
    anvil
    unix
n
1
anvil
scache
unix
n
1
scache
maildrop
unix
n
n
  • pipe
old-cyrus
unix
n
n
  • pipe
cyrus
unix
n
n
  • pipe
uucp
unix
n
n
  • pipe
ifmail
unix
n
n
  • pipe
bsmtp
unix
n
n
  • pipe
please advise
Post edited by: paulfromsurrey, at: 2009/02/27 21:52<br><br>Post edited by: paulfromsurrey, at: 2009/02/27 21:56
Hello There :slight_smile:
Have you tried to use SMTP Authentication ?
On the Outlook program, go to Tools >Accounts > Select account > change properties… and in the Server’s tab Select, My Server Requires Authentication.
that should help.
Filipe
I have checked it and changed the settings but now it doesn’t accept my password. Also when I try and send an email to any of the users I created in my virtual server, I ger an email back with the following error “User unknown in virtual alias table”.
I have checked the virtual domain file for postfix and all the users are there. it also mapps the emails correctly for example charles@gamezgecko.co.uk is mapped to charles.gamezgecko@gamezgecko.co.uk. where "charles" is the user name, "gamezgecko" is the group and "gamezgecko.co.uk" is the domain.
Any one have any ideas?
Hi there,
In cases where it doesn’t work, what error are you seeing? What does it show in the mail logs – either /var/log/maillog or /var/log/mail.log?
I have seen something strange. My website should send an email to contact@mydomain.com but it sends the email to apache@contact@mydomain.com or root@contact@mydomain.com
This only happens with de "contact" email. With others I have the next error:
postfix/error[31386]: 822B9158C59C: to=<other@mydomain.com>, relay=none, delay=0.19, delays=0.15/0.02/0/0.02, dsn=5.0.0, status=bounced (User unknown in virtual alias table).
I don’t understand why I have errors from postfix and dovecot while I’m using google apps for my emails accounts and the emails are being sent using php. Dovecto, postfix, webmail, sendmail, qmail or others shouldn’t show any error because I’m not using this services…
when there is a problem with email, then first is to check DNS
MX A request returns CNAME
WARNING: MX records points to a CNAME.
CNAMEs are not allowed in MX records, according to RFC974, RFC1034 3.6.2, RFC1912 2.4, and RFC2181 10.3.
The problem MX record(s) are:
smtp.pcpluscomputing.com points to [‘pcpluscomputing.com’]
pop.pcpluscomputing.com points to [‘pcpluscomputing.com’]
This can cause problems
Error
MX is not IP
ERROR: Some of your MX records returned by your nameservers are IP addresses. This is not ok per the RFCs and you should change them.
The problem records are:
142.179.95.177
This can cause problems !
Yeah, that “Undefined subroutine &postfix::rebuild_map_cmd” is a Webmin bug that shows up for a handful of folks. It’s correctable with an update from webmin.com.
You can get more details on that here:
http://www.virtualmin.com/index.php?option=com_flyspray&Itemid=82&do=details&task_id=5323
