So maybe I am doing somethng wrong.
when logging in I log into webmin
is this correct?
is this correct?
You’re logging in correctly – I believe Joe’s saying that to do what you’re trying to do with the file manager, the images will only display if the paths are absolute.
On the other hand, the “Edit Website” option available in the Pro version handles the various kinds of paths a bit better and might be a better way of doing what you’re after if you happen to have Virtualmin Pro.
i see, part of the reason for installing webmin and virtualmin was to be able
to see how the editor would work. So at this point I am a little hesitant to
move to the pro.
Thanks Anyway.
