Each time I perform an update it fails due to an Apache error, which I cannot seem to fix despite trying some things from prior posts in the Help! forum. Have I missed setting up something?
Installing package(s) with command apt-get -y install adduser …
Setting up apache2.2-common (2.2.8-12vm.ubuntu0.14) …
Configuration file `/etc/apache2/ports.conf’
==> File on system created by you or by a script.
==> File also in package provided by package maintainer.
What would you like to do about it ? Your options are:
Y or I : install the package maintainer’s version
N or O : keep your currently-installed version
D : show the differences between the versions
Z : background this process to examine the situation
The default action is to keep your current version.
*** ports.conf (Y/I/N/O/D/Z) [default=N] ? dpkg: error processing apache2.2-common (–configure):
EOF on stdin at conffile prompt
dpkg: dependency problems prevent configuration of apache2-mpm-prefork:
apache2-mpm-prefork depends on apache2.2-common (= 2.2.8-12vm.ubuntu0.14); however:
Package apache2.2-common is not configured yet.
dpkg: error processing apache2-mpm-prefork (–configure):
dependency problems - leaving unconfigured
apache2.2-common
apache2-mpm-prefork
Reading package lists…
Building dependency tree…
Reading state information…
adduser is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
After this operation, 0B of additional disk space will be used.
apache2.2-common
apache2-mpm-prefork
E: Sub-process /usr/bin/dpkg returned an error code (1)
… install failed!
