cutech
1
I’ve set up a namecheap api account and am attempting to configure the domain registrar module.
When I attempt to save the account info I get this error:
Failed to save account : Invalid response XML : not well-formed (invalid token) at line 1, column 49, byte 49 at /usr/lib/perl5/XML/Parser.pm line 187
There is another question similar to this that has an http/s error referenced, but I’m not sure they are linked.
Thanks for the assist, and my apologies if I’ve missed a relevant post regarding this.
C.U.tech
rsecor
2
Did you ever figure this out?
I happent to be seeing the same issue, though I have not done much diving into it as of yet.
rsecor
3
File:
./webmin/virtualmin-registrar/namecheap-type-lib.pl
Issue:
The length of $data is empty but the web server expects an integer of 0 or greater.
My fix:
diff namecheap-type-lib.pl.dist namecheap-type-lib.pl
538a539,540
$data_length = 0;
$data_length = length($data) if ( length($data) != ‘’ );
542c544
< &write_http_connection($h, “Content-length: “.length($data).”\r\n”);
&write_http_connection($h, “Content-length: “.$data_length.”\r\n”);
Joe
4
I’ve opened a bug report about this, so Jamie can have a look.
The ticket is here: https://www.virtualmin.com/node/35660
