domain names and :10000 help
I have a server I am running at home that shares a IP address with all the virtual servers I create.
When I type in the URL and the :10000 it always says “This web server is running in SSL mode. Try the URL https://example.com:10000/ instead”.
How can I get it to change to the other virtual server I am using instead of defaulting to the first one?
EX www.example1.com would be example1.com:10000 not just example.com:10000
You should be able to configure the hostname it presents in that message in Webmin -> Webmin Configuration -> Ports and Addresses : Web server hostname.
Or you could have it redirect immediately to HTTPS instead of showing that message, under Webmin -> Webmin Configuration -> SSL Encryption : Redirect non-SSL requests….
