Domain counters explain difference
Webmin version 2.621
Usermin version 2.521
Virtualmin version 8.0.1 GPL
Theme version 26.22
Nginx version 1.22.1
So there are 32 VS on this VM with 32 websites :+1:
but why only 30 SSL websites?
I am pretty sure all have a valid cert.
and expected to be able to click on this summary and get a list of each for comparison - or is there an easier way to find the missing 2?
i just cannot seem to resolve this - i need to learn how to dig around into virtualmin code to figure out where these two numbers are generated :angry:
still cannot find this curious discrepancy :head_shaking_horizontally:
We show the license size minus the number of virtual servers known to Virtualmin, regardless of whether the Apache or Nginx feature is enabled, which indicates how many more domains you can create under your current license.
@illia sorry i may have confused you - the question was about the difference between the number of virtual websites and the number of SSL websites, where do these get generated? - they should be the same and are independent of licence
i am trying to find why they are different - and which websites are missing SSL
To do that, go to “System Settings ⇾ Virtualmin Configuration: User interface settings” and enable “SSL website” under “Feature columns to show”.
Then go to the “List Virtual Servers” page to figure it out.
@Ilia thank you.
that got me there (in a round-about way) - it turned out to be two Alias VS - they have now been deleted - I do not know why they were not picking up new SSL
There was a counting bug that I just fixed. Thanks for pointing it out.
