I am trying to use the install script ./solaris-install.sh
on an Ubuntu 13.04 server, got following errors:
root@ubuntu-lab13:/tmp# ./solaris-install.sh
Creating Virtualmin licence file
Installing CSW package installer
./solaris-install.sh: line 43: /usr/sfw/bin/wget: No such file or directory
./solaris-install.sh: line 45: pkginfo: command not found
./solaris-install.sh: line 47: pkgadd: command not found
it is working, it was my bad that used the wrong script.
My question is now, how do I access it via the web GUI, I had webmin installed on the same server.
when I go to the address, webmin came up instead of Virtualmin (well i need the webmin too), how can I get around that?
Well, the installer may not work properly on Ubuntu 13.04 – if that’s the distro you’re using, that may be related to the problem you’re having. Only Ubuntu LTS releases, such as 12.04, are formally supported.
However, you may want to look in Webmin -> Change Language and Themes, and verify that it’s set to use the Virtualmin Framed Theme. That theme will give you access to both Virtualmin and Webmin.
