On this forum you are using BBcodes to allow us to Bold and italic our posts. How can I find out if I have this capability on my server ?
I have VirtualMin Pro.
Can someone pls give advice on how I can check if I have this and if not how I would install it. I read somewhere that it might require PEAR - but I don’t know anything about that.
I am writing a php script myself, so I need to know if the
php extention is installed as part of my php config.
Looking at my install scripts under VirtualMin
O can install Joomla 1.58 so does that mean I would have
the required php extension already, or does the joomla
also add the extension as part of the installation ?
