Do I need to have installed valid SSL certificate on the domain with Virtualmin in order to call its remote API?
Thanks.
Thanks.
Well, you don’t have to go out and buy a commercial SSL cert or anything – but it probably wouldn’t be a bad idea to make use of the self-signed cert that Virtualmin sets up for you on port 10000.
A lot of sensitive information could get passed around while using the remote API, so it wouldn’t be a bad idea to use some sort of SSL (the self-signed cert is perfectly fine for that).
Thanks. I’m going to purchase an SSL anyways because I am planning to integrate whmcs and virtualmi so I want to have a real certificate, not self signed.
I got a SSL cert for $8 or $9, check it out here -> http://cheapssls.com/
I don’t work for them, nor am I profiting from this in any way… Just trying to help a brother out and save money
Oh, by the way, just get a single domain cert and use it on VirtualMin, as well as UserMin… Then not only is your control panel secured, so is your email login
Even though the single cert domain works on one domain, it will cover both VirtualMin and Usermin… And if you set up a website at the same domain (on port 80, virtualmin + usermin use diff ports) then it will secure it as well… All 3 for $8 or $9 is not bad!
For example, my cert covers clients.mydomain.com, which protects:
clients.mydomain.com:10000
clients.mydomain.com:20000
Pretty sweet, eh? And you dont have to spend $100-$1500 on a wildcard cert
