I’m trying to set up a second server as slave dns / cluster slave server. The main server is runing VM 3.59 Pro on CentOS 5.2, the slave VM 3.59 gpl on Debian 4. According to “Re-Check Config” everything is fine on both servers. But when I try to setup the “Cluster Slave Server” in my VM-Pro installation, I get the following message:
Adding a.b.c.d ..
Added a.b.c.d, with 0 existing zones.
Setup a.b.c.d with 0 new slave zones, but encountered 73 errors :
a.b.c.d : BIND module is not set up
Where can I find these error messages? Any log I checked didn’t show them.
when i had troubles with the slave system, jamie advised me to make the /var/named/slaves or the /var/named/chroot/var/named/slaves folder world-rightable.
the ‘slaves’ folder is 0770 and belongs to named:named
the other folders are 0750 and belong to root:named
Jamie’s a little too fond of the ol’ “chmod 777”.
I’m sure there’s a better ownership and permission combo that’ll work fine.
