For some reason the network configuration > Hostname and DNS Client > DNS servers isn’t persisting true reboots, so i have to enter localhost (127.0.0.1) as a dns server after every reboot.
any ideas on why this is happening? … other changes are saved.
the server is running ubuntu 10.04.
If you’re using DHCP to obtain your IP address, DHCP may reset /etc/resolv.conf each time it obtains an IP address. Editing the dhclient config file in /etc, you can set it to not do that.
There’s a few ways listed here for accomplishing that, I suggestion option #3:
