DNS Secondary not sincronizing
Webmin version 2.202
Virtualmin version 7.20.2 Pro
Webserver version Apache version 2.4.52
Related packages BIND version 9.18.28
I have configured Virtulamin to accept sync as a DNS secondary from a Plesk 18.0.64 system
I seems to be ok as I receive the following message when I test a domain:
Testing transfer of slave zone from xx.xx.75.27 …
… from xx.xx.75.27 : Completed OK
Test transfer successfully fetched 80 records from at least one nameserver. Actual transfers by BIND should also succeed.
But when I sync the two servers virtualmin dns information keeps empty.
Can anybody help me?
Thanks in advance.
Regards
Hermano
Note that this is a test transfer that you are triggering manually.
I think you need to wait for a few hours for the sync to occur automatically, then you will see the records in the secodary / Virtualmin server.
Thank you for the reply.
Unfortunately is already a few days without synchronizing. Even when I force the sync manually doesn’t sync.
Any errors in the logs ? That is the first place to look
I found this error on logs:
/IN: refresh: failure trying primary xx.xx.75.27#53 (source 0.0.0.0#0): tsig indicates error
