Dns question regarding almalinux 9 and virtualbox with virtualmin installed
OS type and version almalinux 9
Webmin version 2.105
Virtualmin version 7.9.0
using virtualbox and installing alma linux everything was fine until an hour or 2 hours dns stop responding dns was not working at all, is there such a problem with virtualmin and almalinux 9?
or it happen because it was on virtualbox and not active server on the internet?
thank you
nikos sarantopoulos
Check your logs, I use Rocky and have had no issues.
No, that’s a silly assumption.
Random process death is usually the OOM killer. But, you’ll need to poke around in the logs to see why it stopped.
How much RAM does your virtual pc have?
Do you mean that you’re hosting it from home?
yes a host in virtualbox until i will design with a server in velia
thanks
nikos
If BIND DNS service was still running and you’re hosting it from home you either need to setup Addresses and Networking ⇾ Dynamic IP Update or better get a static IP address from your ISP.
