Don’t know what happen but I can not access my websites using the domain name, the only way i can get access is by typing the IP address, but even accesing the pages using the IP number, some of the webside pages don’t show correct. Any Ideas?
The Check Configuration from System Settings-> Re-Check Configuration comes out with no problems.
My namecheap.com account and it all seems to be correct,
X Records Oh well, I did not detect any MX records so you probably don’t have any and if you know you should have then they may be missing at your nameservers!
WWW A Record ERROR: I could not get any A records for www.boricuavps.com!
I dont know if namecheap did anything cos they did not email me but the problem have been solved. I did removed some lines from the DNS Record, but dont know if it was that what solve the problem or if it was them that fixed the problem.
