Could one of the webmin.com admins please check the settings for the name servers.
I encounter problems when trying to access the website. Therefore I checked your DNS servers on intodns.com:
Same Glue Looks like the A records (the GLUE) got from the parent zone check are different than the ones got from your nameservers. You have to make sure your parent server has the same NS records for your zone as you do.I detected some problems as follows:
For jamie.cloud.virtualmin.com the parent reported: [‘75.101.128.69’] and your nameservers reported: [‘108.60.199.109’]
DNS servers responded ERROR: One or more of your nameservers did not respond:
The ones that did not respond are:
108.60.199.115
Thank you.
