DNS issue with deactivated Domains
Since last update, I got some warning-messages for domains who are currently deactivated.
Any Idea why this happens since last update, and how to handle it in the right way?
Is it a bug?
As there are just disabled domains are listed, it seems to me, the handling of disabled domains in dependency to DNS-Entries are not correct?
Example for sturzpad.com:
In my opinion (just guessing) the issue seems to be, that the DNS-entries are renamed to: sturzpad.com.disabled, but the file is still named: /var/lib/bind/sturzpad.com.hosts
Even enabling and re-disabling the domain don’t change this at least.
Moved those domains now to another server.
Don’t know what the issue was at least, as at this server are also other Domains set to state: disabled.
They don’t appear in the warning message.
Can you show exactly what that zone file looked like?
