On my server, I’m using virtualmin, and the server is hooked up to my router, so it has it’s own private IP. virtualmin is using this ip instead of the public IP, which I know it can see, since it shows it on the dynamic domain updating. I need the DNS server tu use this (dynamic) external IP instead of the private ip, which is is currently using. How would I do this?
oops, double posted it. sorry!
System Settings -> Module Config -> Server Settings -> Default IP address for DNS records (you put public IP there)
that won’t work, since I have a dynamic IP and I don’t want to go there every day and change the IP.
