Do you get any errors in the syslog on the master server? Is BIND listening on TCP port 53 for external addresses? Is a firewall blocking incoming TCP traffic on port 53 for the master?
The text of the error I posted was from the syslog of the slave. The master does not output anything.
Master to Slave:
Starting Nmap 4.62 ( http://nmap.org ) at 2010-11-16 16:03 PST
Interesting ports on 68.71.37.23:
Not shown: 1708 closed ports
PORT STATE SERVICE
21/tcp open ftp
22/tcp open ssh
53/tcp open domain
80/tcp open http
623/tcp filtered unknown
664/tcp filtered unknown
10000/tcp open snet-sensor-mgmt
Slave to Master
Starting Nmap 4.62 ( http://nmap.org ) at 2010-11-17 00:06 UTC
Interesting ports on 202.lostsignalnetwork.com (68.71.45.202):
Not shown: 1703 closed ports
PORT STATE SERVICE
21/tcp open ftp
22/tcp open ssh
25/tcp open smtp
53/tcp open domain
80/tcp open http
Okay, seems the systems can reach each other fine.
Please check the syslog of the master server too, if any errors are recorded there.
Also check the BIND module in Webmin, section Zone defaults, if there’s any entry in “Allow transfers from”, and if so, if it’s the right IP. The same you can do for the respective zone, section Zone options.
