Disk Quotas part not showing in my dasboard
how to add
@Uddhab_p,
Is quotas enabled on your server? Not all systems enable quotas by default, sometimes either a missing package prevents it from doing so, or you need to enable quotas manually on the partition for it to start working.
Check…
Webmin > System > Disk Quotas
This will tell you the current status of quotas across various partition points.
Hope this helps!
Best Regards,
Peter Knowles | TPN Solutions
*** need professional, affordable technical support? check out https://tpnassist.com ***
here status Screenshot by Lightshot
@Uddhab_p,
Aa suspected, quotas are not enabled yet. If this is a newly created server, reboot and it should fix your problem. If not there may be further steps to be taken.
When you indicate during the post installation wizard your intent to use quotas on an XFS mounted system, it would have told you to reboot for this to take effect.
Best Regards,
*** Need Professional, Affordable Technical Support? Visit https://tpnassist.com ***
