Disabling SSL not working
Hello, I have dedicated server running on Centos6. I installed Webmin and configured my domain as http://example.com and installed a RapidSSL certificate.
I did try to disable SSL, but then i can’t access https://example.com.
When I am trying to connect to http… it works perfectly alright. Only problem is with https…
When I am trying to connect to https it isn’t open from “/home/…/example.com/public_html”, but redirect to “/var/www/html/”.
Can you help me solve this problem?
Hmm, the existing default section of the Apache config may be overriding your new SSL setup.
Can you post the contents of your /etc/httpd/conf.d/ssl.conf file?
I suspect it’s something in there causing the issues you are seeing. Thanks!
# LoadModule ssl_module modules/mod_ssl.so # ... ## ## SSL Virtual Host Context ##
Use separate log files for the SSL virtual host; note that LogLevel
is not inherited from httpd.conf.
ErrorLog logs/ssl_error_log
TransferLog logs/ssl_access_log
LogLevel warn
SSL Engine Switch:
Enable/Disable SSL for this virtual host.
SSLEngine on
Server Certificate:
SSLCertificateFile /etc/pki/tls/certs/localhost.crt
Server Private Key:
SSLCertificateKeyFile /etc/pki/tls/private/localhost.key
<VirtualHost default:443>
LogLevel warn
SSL Engine Switch:
SSLEngine on
Server Certificate:
Server Private Key:
