Centos 5.4, x86_64, clean install, with no options selected other than basic server. Then did normal YUM udpate, reboot, followed by install.sh for Virtualmin Pro.
The install works as expect and I can login to VirtualMin and see everything installed.
I went to install apc for PHP, and noticed when I installed got errors, so I run yum install httpd-devel, I have dependency errors.
Here is the log:
[root@centos1 etc]# yum install httpd-devel
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
- addons: mirror.rackspace.com
- base: mirror.ash.fastserv.com
- extras: mirrors.netdna.com
- updates: mirror.rackspace.com
Setting up Install Process
Resolving Dependencies
–> Running transaction check
—> Package httpd-devel.i386 0:2.2.3-31.el5.centos.2 set to be updated
–> Processing Dependency: httpd = 2.2.3-31.el5.centos.2 for package: httpd-devel
–> Processing Dependency: apr-util-devel for package: httpd-devel
–> Processing Dependency: apr-devel for package: httpd-devel
—> Package httpd-devel.x86_64 1:2.2.3-22.el5.1vm set to be updated
—> Package apr-devel.x86_64 0:1.2.7-11.el5_3.1 set to be updated
—> Package apr-util-devel.x86_64 0:1.2.7-7.el5_3.2 set to be updated
–> Finished Dependency Resolution
httpd-devel-2.2.3-31.el5.centos.2.i386 from updates has depsolving problems
–> Missing Dependency: httpd = 2.2.3-31.el5.centos.2 is needed by package httpd-devel-2.2.3-31.el5.centos.2.i386 (updates)
Error: Missing Dependency: httpd = 2.2.3-31.el5.centos.2 is needed by package httpd-devel-2.2.3-31.el5.centos.2.i386 (updates)
You could try using --skip-broken to work around the problem
You could try running: package-cleanup --problems
package-cleanup --dupes
rpm -Va --nofiles --nodigest
The program package-cleanup is found in the yum-utils package.
I do this exact same setup on I386, and it works fine. Somewhere, somehow the x64 libs/repositories don’t have something right.
