Default F2B settings on Deb13
Webmin version 2.653
Usermin version 2.552
Virtualmin version 8.1.0 GPL
Theme version 26.50.4
Apache version 2.4.68
Im guessing this one is for you Ilia
We have just moved our 2 NS servers over to Deb 13 and I have noticed that there now appears to be a new virtualmin config file that is created at installation time for F2B
It now seems that the default action is rich-rules which fills the firewall with this
The old way way was like this
So where we had all ips grouped into the the jail they were put in it now appears we have 1 line per ip address. The interesting is I have noticed is the same IP address is appearing in multiple lines which is telling me the IP address is NOT being banned correctly otherwise this would not be possible
eg
Also the same IP address is in multiple jails
This is leading me to believe something is broken and the rules are not working. For example once an IP is listed in the recidive jail which bans them for a week its should not be possible then reappear in the postfix jail some hours later.
I’m all ears
Michael
Thanks for reaching out!
Did you install Debian 13 clean or did you migrate from a previous Debian version using distro upgrade?
Also, what is the output of the following command:
dpkg -l | grep firewalld
Hi Ilia
Always a clean install,
root@ns2:~# dpkg -l | grep firewalld
ii firewalld 2.3.1-1+deb13u1 all dynamically managed firewall with support for network zones
ii python3-firewall 2.3.1-1+deb13u1 all Python3 bindings for firewalld
Michael
Ah, I see now… Try making virtualmin-firewalld.conf fail2ban config file look as:
[DEFAULT]
port = 1-65535
banaction = firewallcmd-rich-rules
banaction_allports = firewallcmd-rich-rules
Restart fail2ban and let me know if the original issue is solved?
Hi Ilia
Yes that has now got it working.
Don’t forget to update the install script so I don’t bug you again :laughing:
Michael
Thanks, ran into the same problem on Debian 12. When checking the config I wonder why there are rich rules instead of ipsets. Will ask in another topic
so this is Debian only file. Rocky I don’t see the file, but found this one
Do I update to the same?
As described in the comment linked below, it’s better to configure Fail2ban to use IP sets:
