Hello, I have searched through the forums and google my issue for a few hours now and to no avail I can’t fix this issue.
I have 4 virtual servers set up.
2 Of them currently say they are the default for the IP address.
Example
V1 - Default = YES
V2 - Default = No
V3 - Default = No
V4 - Default = YES <- STUCK! I can switch the default between V2, V3 and V1, but V4 never changes, however is also NOT acting as default.
If you look at your Apache config files, and review the VirtualHost block for those domains – does it look the same in each case? Do you see the same IP address listed?
One possible cause of what you’re seeing is that the VirtualHost block has something unusual in it (such as another IP address, or perhaps a “*” character).
