On a fresh Debian Lenny 5.0.1 64bit install, using the GPL install.sh, there is the following issue, whats wrong ?
INFO - 2009-06-18 21:24:35 - Installing dependencies using command: /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install postfix postfix-pcre webmin usermin ruby libapache2-mod-ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip
Reading package lists…
Building dependency tree…
Reading state information…
Package webmin is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
FATAL - Fatal Error Occurred: Something went wrong during installation: 0
/root/virtualmin-install.log has no more information :
INFO - 2009-06-18 21:24:22 - Started installation log in /root/virtualmin-install.log
DEBUG - 2009-06-18 21:24:22 - Install mode: full
DEBUG - 2009-06-18 21:24:22 - Product: Virtualmin GPL
DEBUG - 2009-06-18 21:24:22 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2009-06-18 21:24:22 - install.sh version: 1.0.3
INFO - 2009-06-18 21:24:22 - Checking for fully qualified hostname…
INFO - 2009-06-18 21:24:22 - Hostname OK: fully qualified as r20277.ovh.net
INFO - 2009-06-18 21:24:22 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2009-06-18 21:24:22 - Loading OS selection library…
INFO - 2009-06-18 21:24:23 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2009-06-18 21:24:23 - Loading OS list…
INFO - 2009-06-18 21:24:23 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2009-06-18 21:24:24 - Operating system name: Debian Linux
INFO - 2009-06-18 21:24:24 - Operating system version: 5.0.1
INFO - 2009-06-18 21:24:24 - Configuring package manager for Debian Linux 5.0.1…
INFO - 2009-06-18 21:24:24 - Enabling universe repositories, if not already available…
INFO - 2009-06-18 21:24:24 - Disabling cdrom repositories…
INFO - 2009-06-18 21:24:29 - Cleaning up apt headers and packages, so we can start fresh…
INFO - 2009-06-18 21:24:33 - Download of http://software.virtualmin.com/lib/apt.conf.noninteractive Succeeded.
INFO - 2009-06-18 21:24:33 - Installing Webmin and Virtualmin package signing keys…
INFO - 2009-06-18 21:24:33 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-virtualmin Succeeded.
INFO - 2009-06-18 21:24:33 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-webmin Succeeded.
INFO - 2009-06-18 21:24:34 - OK
INFO - 2009-06-18 21:24:34 - Hit
INFO - 2009-06-18 21:24:35 - Removing Debian standard Webmin package, if they exist (because they’re broken)…
INFO - 2009-06-18 21:24:35 - Removing Debian apache packages…
DEBUG - 2009-06-18 21:24:35 - Reading
FATAL - 2009-06-18 21:24:38 - Fatal Error Occurred: Something went wrong during installation: 0
FATAL - 2009-06-18 21:24:38 - Cannot continue installation.
FATAL - 2009-06-18 21:24:38 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2009-06-18 21:24:38 - re-attempted after any problems have been resolved.
FATAL - 2009-06-18 21:24:38 - Removing temporary directory and files.
FATAL - 2009-06-18 21:24:38 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2009-06-18 21:24:38 - in /root/virtualmin-install.log
Thanks,
Julien
