| SYSTEM INFORMATION | |
| OS type and version | Debian 13 |
| Webmin version | 2.641 |
| Virtualmin version | 8.1.0 |
| Webserver version | Apache |
| Related packages | SUGGESTED |
Clean install from Hetzner repo.
Cyrus SASL Authentication Server failed to start.
Root Cause — Two Problems
- PID file directory
/run/saslauthd/doesn’t exist → systemd can’t write the PID file → startup times out - Socket path mismatch — saslauthd is writing to
/var/spool/postfix/var/run/saslauthd/mux(wrong nested path), systemd expects/run/saslauthd/
Fix 1 — Create the missing directory + persist across reboots
bash
mkdir -p /run/saslauthd
chown root:sasl /run/saslauthd
chmod 710 /run/saslauthd
# Make it survive reboots via tmpfiles.d
echo 'd /run/saslauthd 0710 root sasl -' > /etc/tmpfiles.d/saslauthd.conf
Fix 2 — Correct the socket path in /etc/default/saslauthd
bash
nano /etc/default/saslauthd
ini
START=yes
MECHANISMS="pam"
MECH_OPTIONS=""
THREADS=5
OPTIONS="-c -m /run/saslauthd"
The -m /run/saslauthd is the canonical path — not the nested postfix chroot path.
Fix 3 — Give Postfix access via bind mount
Since Postfix runs chrooted at /var/spool/postfix, it can’t see /run/saslauthd directly:
bash
mkdir -p /var/spool/postfix/run/saslauthd
# Add bind mount to /etc/fstab so it survives reboots
echo '/run/saslauthd /var/spool/postfix/run/saslauthd none bind 0 0' >> /etc/fstab
# Mount it now without rebooting
mount --bind /run/saslauthd /var/spool/postfix/run/saslauthd
Fix 4 — Update Postfix SASL config
bash
nano /etc/postfix/sasl/smtpd.conf
pwcheck_method: saslauthd
mech_list: plain login
saslauthd_path: /run/saslauthd/mux
Restart & Verify
bash
systemctl restart saslauthd
systemctl status saslauthd
# Confirm socket exists
ls -la /run/saslauthd/mux
# Test auth
testsaslauthd -u youruser -p yourpassword -s smtp
# Restart Postfix
systemctl restart postfix
You should now see Active: active (running) with no timeout. The key was the missing /run/saslauthd/ directory — systemd’s Type=forking waits for the PID file to appear and kills the process when it never does.
Survival Risk Assessment
| File/Change | Risk | Reason |
/etc/default/saslauthd |
Medium | Virtualmin may reset this during postinstall scripts |
/etc/postfix/sasl/smtpd.conf |
Medium | Virtualmin manages Postfix configs |
/etc/tmpfiles.d/saslauthd.conf |
Safe |
Not touched by Virtualmin |
/etc/fstab bind mount |
Safe |
/etc/dovecot/conf.d/20-pop3.conf |
High |
Virtualmin actively manages Dovecot config |
