I’m struggling with the postfix configuration and spam and virus checking. I don’t know where to place the spam and virus checking. Are there example files for
main.cf
master.cf
procmailrc
amavis-new.conf
etc…
which integrate nicely with virtualmin (users can choose if they want spam and virus checking).
thanks,
Martijn
It depends on what you want to do. Have a look at the Servers>Spamassassin Webmin module. It has a function to set up procmail so Spamassassin will be user-configurable via Usermin.
ClamAV doesn’t have per-user options in Webmin/Usermin, that I know of. You can control it globally with a third-party module:
http://wbmclamav.labs.libre-entreprise.org/
That seems to work best when doing ClamAV with amavisd-new.
Good luck.
