And through it sounded like a good idea so I installed it and its VirtualMin module, but I soon found out it has massive impact to the speed websites would load, so I run the uninstall script on it! sadly the uninstall has left the CSF Dashboard message, and it has also said that my firewall is disabled?
How can I fully remove CSF from the VirtualMin dashboard and make sure its not blocked my firewall.
I did actually install UFW before I installed VirtualMin so not sure if VirtualMin works with that.
I really doubt that. ConfigServer Security & Firewall is very stable and speedy product.
Sadly the CSF Module is not present in the delete list of Modules, I wonder if the uninstall script removed it but somehow kept the Dashboard front page change?
I run your systemctl commands and the firewalld service is running.
