SYSTEM INFORMATION | |
OS type and version | Ubuntu 22.4.3 |
Webmin version | 2.101 |
Virtualmin 7.8.2 |
I have installed csf but “ConfigServer Security & Firewall” won’t show in “Webmin / System”
I also use csf in Debian 12 where it shows ok.
What to do?
Virtualmin 7.8.2 |
What to do?
Is this installed using a script in Webmin/Virtualmin or is it installed outside?
What do you mean by installation? Standalone package or package and its module for Webmin?
Searching the Internet for webmin csf module I found this ConfigServer Security & Firewall - Webmin Documentation
I installed it in CLI.
Thanks.
Now I followed “File:Csf install module.png - Webmin Documentation”
but it is the same. I´ll try to reboot.
Do you see it now?
Try Refresh Modules?
If you edit the webmin user you should see it, is it ticked?
Yes, It’s there now. Thank you both.
