hello,
i have setup a cron job to execute a php file every 5 minutes, so i highlighted every item on the list,
“when to execute” is set at "Times and dates selected below … "
and every minute is highlighted, 0 to 59.
But still the script is executed every minute…
all other time unit (hours, day) are set to “ALL”
please see the picture attached
that worked until the server was moved to another datacenter, i had to reboot webmin also. is it a reason for the cron not working? thanks .
hi, thanks for the advice.
Fortunately i had my php script that logs its own execution on a table that’s how i knew the Cron did not function properly.
